Port of A 4th Order
daltone34
US
So. I'm planning and designing a build for 6 SA 12's in a 4th order in a SUV and I was wondering when using an online calculator for port tuning and measurements do you use just the ported portion's volume or would I use the combined volume of the ported and sealed portion? Thanks.
Sent from my SM-N920V using Tapatalk
you are going about this all wrong if you are using an online calculator.
You also want a meter to know the exact peak resonance of your sealed section so you can tune your ported side to that to get the best output and bandwidth. If you are just building blindly it'll be a disaster.
Ok thanks
That's what I was thinking but I never like to be simple haha
flatwall will definitely be easier to get loud then a 4th order built without a proper term lab/RTA. Just build the wall with a lot of airspace and port then start shrinking the port till you get the best result. My buddy had to tear down his 4th order wall, convert it to 6th order wall, still didnt do so hot and now finally a flat wall and he's 6 db louder with the flatwall then the 4th order setup on fewer subs. So unless you like tearing down your sh*t, just make life easier and louder with a flat wall lol.
flatwall will definitely be easier to get loud then a 4th order built without a proper term lab/RTA. Just build the wall with a lot of airspace and port then start shrinking the port till you get the best result. My buddy had to tear down his 4th order wall, convert it to 6th order and now finally a flat wall and he's 6 db louder with the flatwall then the 4th order setup.
I hear you. I dunno.. I LOVE the lower bass (around 30-40 Hz is my happy zone) but also want to still keep my higher frequencies like 55 Hz to hurt more so would I still be able to do so with a flatwall?
yeah, 4th order will kill higher frequencies super fast like literally dead a few hz right after port tuning, I would not recommend it. You'll have much better luck with flatwall with what you want. Thats basically the ideal bandwidth you achieve with flatwall but you'll play a bit lower as well down to 25hz or so and still hurt in the 50hz range.
yeah, 4th order will kill higher frequencies super fast, I would not recommend it. You'll have much better luck with flatwall with what you want. Thats basically the ideal bandwidth you achieve with flatwall but you'll play a bit lower as well down to 25hz or so and still hurt in the 50hz range.
Thanks, man! So, flatwall tuned to about what frequency? Sorry to keep bothering you with these questions lol
wtf? I myself like to keep things simple and not overcomplicate things. Unless you know what your doing or have a good enclosure/wall designer on duty that you know of.
i'd say start high with higher port area and tuning then gradually shrink your port (add wood pieces) and lower tuning till its at the response you like.
I'm just weird like that I guess.. If it's complicated then it's me lol
Thank you
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
907
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
626
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
783
755
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
daltone34
daltone34
US
mlstrass
slater
    May 2, 2024
slater
    May 2, 2024
