port noise on recones.....
SlickCMRick
Ok, so I reconed my subs and now all of a sudden I have port noise. My subs before in the same box had no port noise. One problem may be that I upgraded my amp from 1700w to 2700w. If I have more power, do I need a wider port? If I recone the subs (but keep the same basket and motor) will it change the T/S specs? My box now was built to my original subs t/s specs.
Sorry im a noob with this but im trying to learn. I searched but didnt come up with anything..
thanks for any help
i knew you would ask that :p
im thinking around 60......cant remember exactly but im pretty sure it is 60. i know it was the most port area i could get with my measurements.
yeah and the port is 4" wide........if its built to eclipse t/s specs but has re soft parts. does that matter?
Yes, different soft parts will have different T/S parameters even using the same motor, this can shift around in frequency and amplitude where the maximum vent air volecity occurs.
SlickCMRick
SlickCMRick
Las Vegas
Volenti
