Poll (w/pics): Which type of bracing Is better for my box?
Which bracing is better in my case?
  • Image 1
    Votes: 7 46.7%
  • Image 2
    Votes: 6 40.0%
  • Neither, I have a better suggestion below
    Votes: 2 13.3%
  • Total voters
    15
ARSkemp
FI-AQ-PA-AB-Profile-MB-RD
Box is ~4ft^3 tuned to 40hz with a ~8" aero. Probably for 2 HDC312s. Double baffle on top, triple for just the aero (to keep it a diameter's distance from the back wall).
Which type of bracing would be better in this case?
Image 1 (1.5" Dowels)
Image 2 (don't know the name of this bracing, using .75" mdf just like the box)
the only thing that sucks about all thread is having some of it stick out the box and the nut on the end. it looks shitty
I prefer dowels but both are good. If you do window bracing (image2) then roundover both sides of the openings and it'll be fine too.
#2 is window bracing, much stronger then dowels as it has much more contact area.
Not that hard to do and just use a roundover bit to smooth em over. I usually make mine about 1 1/2" wide for the frame part...
#2, not even close. Dowels are all but useless in anything other than bookshelf size loudspeakers.
Without trying to be rude, people don't seem to be a bit confused about what bracing is or how it works. Threaded rod is NOT bracing. It is used to eliminate opposing panel flex. Bracing works to lower enclosure resonance by raising the resonant frequencies of the panels. Think about it like this: why are the low notes on a piano the long strings and the high notes the short strings? Why is it that when you touch one of the long strings and pluck it, the note is higher? You're changing the resonant frequency of that string. Damping the string, which is what those pads are actually called, removes the resonance. Damping the enclosure is what bracing does. Threaded rod does not damp anything like wood does; you use it in high power applications where you need the box to just not flex apart under high pressure loads.
So would 1 1/2" be you recommendation even though the box isn't very deep? The box in the images is only 12.5" net depth (from front to back in the inside) and I don't want to impede airflow too much...
Definitely learned something new from this, thanks for the response.
if using MDF then yes 1 1/2" minimum as MDF isn't very strong and could still flex, especially if the window part is too small...
Alright, so for the 1.5" part, do you mean the width of the pieces of the frame (so that the "window" created by the frame is smaller/larger depending on the width) or do you mean the thickness of the window (like stacking 2 .75" mdf windows together, like a double baffle)? or both?
ok cool. well would you use both for a box for my set up in my sig?
thanks
ok cool. well would you use both for a box for my set up in my sig?thanks
No. Threaded rod is for people who have multiple high powered drivers in a single chamber enclosure. While wood glue is going to hold the box together, the flex caused by the sound pressure can cause the wood to flex and therefore become stressed. That's when you use rods. For damping resonance, i.e.
Versus for eliminating flex:
Rod is used when you have very large panels because you have large airspaces that extensive bracing would take away from and you're just wanting maximum output.
ARSkemp
ARSkemp
Salas/Chico, CA
marcotheclepto
