L lostsoul 10+ year member Heretic 2,260 1 Houston Jul 28, 2006 #1 How much space needs to be between the pole vent and the back of the box? Im trying to fit a bigger sub into a shallow box. Click to read more...
2loud4u 10+ year member Nothing to see here 2,250 0 canada Jul 28, 2006 #2 How ever wide the vent is leave that much space.
CBFryman2 5,000+ posts Banned 5,848 4 Lake Shitty Jul 28, 2006 #3 if you want to be technical... take the area of the pole vent and devide it by the diameter.
CBFryman2 5,000+ posts Banned 5,848 4 Lake Shitty Jul 28, 2006 #4 or just not worry about it. it depends on the driver //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
OP L lostsoul 10+ year member Heretic 2,260 1 Houston Jul 29, 2006 Thread Starter #5 well its a brahma and it would almost be touching the back of the box. Im thinking thats a bad idea...
tommyk90 5,000+ posts THE WHOLE THING!!! 16,870 76 Chicago Heights, IL Jul 29, 2006 #6 well its a brahma and it would almost be touching the back of the box. Im thinking thats a bad idea... Click to expand... I would leave at LEAST an inch or so of room (more if you can fit it) to get some airflow back there. If you choke that off too much, there's a possibility you can heat up the coil too quickly/too often.
S squeak9798 5,000+ posts Banned 26,540 97 USA Jul 29, 2006 #7 "Adequate" would be to leave an distance of half the diameter of the pole vent. But it's better if you can leave atleast the diameter of the pole vent.
Fi Car Audio 10+ year member Senior VIP Member 290 0 Hades, NV Jul 29, 2006 #8 Squeak9798 has the same "minimum" rule that I use. 1/2 the diameter will work.
B Blunt 10+ year member 2009 ProStock 0-600 Champ 2,246 83 Somewhere Jul 29, 2006 #9 jsut put an mdf ring on the baffle and mount the sub to it should provide enough
