please help with neon lighting??
chinxtaboi
tx
please help
this will be my first installation of any sort. I want to put sum neons in my car... but where do these wires go???
i understand everything up until the wiring to the battery part. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i dont think the wires are suppose to run directly to the battery... or are they? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
any help will be VERY much appreciated...
thank you
well im gonna run maybe 2 36" neon tubes in the car... not gonna be on all the time..
just when im cruisin at night.
can anybody help... im jus not wuite sure how to run the wires to the power source.
do i run it DIRECTLY to the battery? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You would run the NEGative to a ground. The posative wire you would run to a switch so that you could control whether the lights are on or off. You would then connect +12Volt to the other terminal on the switch, ignition, battery your choice
ok... so ground the negative (black) and positive goes to switch...
i think i got it
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
IF you run it directly form the battery to a switch, fuse it as close to the batt as possible....or connect it up to the remote turn on and get whatever relays you need to power it. im not too sure as to what amp fuse...so...yea. -scott
crap!... i had everything goin.....
abig neon tube all hookd up wit the distribution block and switch....
everything was A ok.....
then i added sum more neon tubes... everything was working fine..
then i turned off the switch.....turnd it back on.... nuthins turning on!!!!
whats wrong!?
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif :banghead: //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif :banghead:
whats wrong!?
Check the fuses
Anything with ballasts or motors needs more power to start up than it does to keep running. With motors sometimes 2X as much power.
Neon lights have ballasts that turn the 12-volt in your car into about 10,000volts.
when you fire up your neon lights. If when running they draw a total of say 10 amps, then I would use at least a 15 amp fuse, thius will allow for a surge of power when the ligts first turn on
can sumone please explain to me this fuse scenario...
how would i go bout changing it or whatever needs to be done...
please... i know its a stupid question but.. this is my first actual install of any sort
any help is very much appreciated
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif :banghead: //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif :banghead: //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
thank yall so much... dis has been a learnin experience
yea the fuse blew..
fixed.. now my ride is shinin
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
Originally posted by shrinkydinx the fuse would be on the red wire, between the battery and the switch, in some sort of fuse holder. go to track auto and buy a similar fuse and replace it, if it looks blown. if it is blown, the metal inside the fuse will be broken.
Hey! Jackass! Fuses do not always LOOK blown even tho they are.
chinxtaboi
chinxtaboi
tx
Alaxan
    Jun 20, 2026
    Jun 20, 2026
