Please confirm that this is a GREAT box design for FI Sp4 D1
  • 6
artrilliance
Will be running Autotek MM4000.1d, 250amp alternator, xs 3100, Shiruken 100ah
Yes, I designed it and have redone the calculations for double baffle and bracing is already accounted for. As far as the port, it is 12.17 sq in. Should the 4" port width be wider, is that what you are suggesting?
I'm pushing to go for the larger box, smaller 4.5" port of around 14" cu in per foot, and keeping the tuning lower. Will this be a good compromise? My trunk space is maxed out and I feel from the WinISD graph that the larger box will have a smoother curve as well as gain closer to 3DB.
How is it looking?
599
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
486
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
artrilliance
artrilliance
Salem Oregon
artrilliance
    May 31, 2024
    May 24, 2024
