Planning to build a box...what materials?
The Driver is a Xenon 10" 2 ohm. It has a chart, with .42 internal volume(with driver) going for SPL, and .85(with driver) as an SQ oriented build. I was thinking .65 to .75 with driver would be good for me.
As far as resin, I've never used the stuff, but my dad has 2 gallons of it after his repairs on his log truck (fiberglass hoods on the big trucks). Is it just apply and let set situation? This would help me make the box fit perfect to the trunk wall //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
~Levi
When they say the SPL enclosure being small, that means it's going to have a peak in the upper frequency spectrum and it will have very little low end. If you don't care about having low end, .65 will probably be fine.
I thought SQ was when there was very little low bass, but more accurate reproduction? I'm aiming at 75% SQ with some 25% extra bass. Hence the .65 volume with driver.
So to achieve that, you are saying I'd be better off with a .55 for my idea? I'm new to sub box designs, I apologize.
~Levi
~Levi
i wanna know how u take percentages of things that arent numbers?
~Levi
No. The smaller you go, the more of a peak you will create, thus the louder the box will be at higher bass frequencies. The smaller the enclosure, the less low end response you will have.
Give me the T/S parameters and I'll get you a proper size for that sub.
As stated before,
.85 cubic feet with drivers' volume= Musical (reprodcution)
.42 cubic feet with drivers' volume= SPL
So actual 75%/25% split is either
.6375/.2125 for Musical split (desired) = .6375 for musical 75%/25%
.3150/.1050 for SPL = .5250 for SPL 75%/25%
If my math is correct //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
As for the //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif I meant as in better high response punch rahter than lower bass (rock listening rather than rap) in a sealed enclosure.
On a side note, the enclosure rough sketch i made only has .64 volume without the driver //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
~Levi
As stated before, .85 cubic feet with drivers' volume= Musical (reprodcution)
~Levi
Low bass is NOT just for rap, that is a terrible generalization.
Link me to the sub. Is this the correct sub:
ftp://208.187.38.55/Phoenix_Gold/Manuals/Speakers/xenon/
If it is, I would do no less than 1 cubic foot. They recommend 1.65 for musical and I agree with it all the way.
Phoenix Gold Xenon 10" 2-ohm:
T/s Parameters:
Fs=18.7Hz
Re=3.46 ohm (series)
QMS= 30.19
QES=.43
Qts=.42
Vas= 43.97 Liters
Mms=277.7 grams
Cms=260 uM/newtons
BL=16.3 Testa-M
SPL(2.83 volts)=85.31 dB
Sd=346.4 sq. cm
Xmax=40MM p-p *measured*
Hope that helps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
~Levi
Sorry for the generalization, once again new to this thing. I've only dealt with midbass up.
Are you looking at vented? It does say 1.7 for vented, but I am working with a sealed box.
Technical sub name is X10d2
~Levi
As said, particle board will crumble. Particle board does not = MDF.Other available wood is Trupan (Light MDF) and Baltic Birch ply. Both are more expensive than MDF, but superior materials
hmm I never heard of this before,how much more is it compared to MDF?
~Levi
The manual I downloaded was for a different generation of the Xenon line. The parameters were very different.
For your sub, I would do between .7-.85 cubic feet. That would give you a smooth and flat response and still be able to get pretty low while sounding nice. Your .65 would work as well.
What is the Drivers' volume so I can add that into my box design? I really wish I could figure it out.
My current box design is about .64 Without the driver. So obviously I need to add something to that, or polyfill.
~Levi
Frankensuby
I'm in Ur F0rumZ
Frankensuby
PA
Frankensuby
