Pioneer single din rec
  • 4
Jeremy11
So 80prs vs x8800bhs. The only difference on paper that matters to me is 16 band eq vs 13 band and 5 volt preamp vs 4 volt. The prs80 is $170 more. Is the prs80 better built or something? Is it really worth the extra money? Any input and recommendations are greatly appreciated!
I was shopping single dins and was contemplating 80prs, x8800bhs, and the deh-s6220bs. In the end I decided that the 80prs was more than I needed and had budget for but actually chose the 6220bs over the x8800bhs because it was 60$ cheaper and the 6220 has the the 13band eq (31 with the app). The x8800 has hd radio but I listen to bt, xd’s and xm
Thanks for the recommendation it gives me something to look at. Because when I listen to the radio its not something that I have loud or are looking for sound quality out of, usually just sports talk or a ballgame.
Then yah, save yourself an extra 60$ and get something with a 31 channel eq (with the app). Btw the prs 80 is pretty cheap right at $237 right now so If $200 was your budget it’s not much more. Otherwise that $120 6220 puts you closer to the $100 budget which was where I was
Wheres it at for 237??
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
345
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
765
Jeremy11
Jeremy11
Loganville,GA
Jeremy11
    May 18, 2024
    May 16, 2024
