Pioneer prs 80 head unit installation help.
Hi I have Just got a pioneer prs 80 head unit for my Clio 197 07 plate. I have removed the standard Cabasse unit but the connections from the Cabasse won't directly fit on the pioneer. I can't seem to find the correct lead so any help would be appreciated. Please find attached the two leads that were attached to the cabbasse.
Regards
Andrew.
I know this will not be the reply your looking for. But your best option is to buy a cheap multimeter so you can find you power, ground and remote wire first. I'm assuming you don't have a aftermarket head unit wiring harness?
Regards
Andrew.
What...Its just a few wires you gotta splice.
RENAULT Car Radio Stereo Audio Wiring Diagram Autoradio connector wire installation schematic schema esquema de conexiones stecker konektor connecteur cable shema
maybe that'll help.
Contact Crutchfield. They may have a wiring harness for u.
Not really though thanks.
---------- Post added at 05:42 AM ---------- Previous post was at 05:41 AM ----------
Nope.
andrewjsexton82
andrewjsexton82
Colchester
andrewjsexton82
michigan born
    May 14, 2026
michigan born
    May 14, 2026
