Thats not really the point I was trying to make but thanks for the response anyway. I was responding to the guys that have 2 din units in their dashes. I was merely saying I like the idea of having only 1 din unit in my dash.1) When using the 9860/9861/or higher you only need 1 din opening (unless you intentionally purchase the double-din W200) since those units fully control the H700/H701
2) The DEQ-P9 can only be used with the P9 headunit. The H701/H700 can be used with any headunit and therefore implimented into any system. This is the only time you would need to use the C701 controller and take up 2 din slots (but, ofcourse, the C701 is only really needed for tuning and volume control when running digital...so if you are running analog you do not need to permanently mount the C701 once you have the H701 set to your liking)
As for your second paragraph, I wouldn't buy the P9 deck without the P9 processor. Therefore I wouldn't need to implement the P9 processor into ANY system. I chose the P9 and that is what I'm going to use and am NOT worried if it will work with another headunit down the road. All in all, with flexibility aside the P9 will perform just as well as the 701 if not better. A PEQ is only useful if your vehicles interior acoustics need it. Other than that I see no reason why a dual 31 band graphic EQ couldn't do the job just fine.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
