Concept 10+ year member
How do I hook up a tweeter amp. Its a Pioneer GM-840. I need to know what parts I need and how to hook it up.
Im not useing stock head unit, it does have the RCA inputs. The amp dont have power or remote wire inputs. All it has is RCA inputsWow. I haven't seen one of those amps in about 15 years. You'll need power wire, ground wire, remote turn on wire, speaker wires ans RCA cables. Basically, a run of the mil amplifier wiring kit. Before buying stuff, we need to know if you have a head unit with RCA outputs or if you're using your stock radio in which case you'd need a line level converter to convert your stock radio's speaker level outputs to RCA outputs.
