* Pioneer Engine Whine / Ground Loop Fix*
SethPhillips
I'sa Playa
Here is IMO the proper way to fix the problem with Pioneer headunit's and the troubles of installing multiple amps, witch in some cases will cause a ground loop...
the way i do it is oposite of how the other stick that was made on this topic.
Take #1
-the external RCA jack's plug.
-what i do is take 20 ga primery wire. strip back 1 1/2-2'' of the outter caseing, then wrap the wire around the outter part of the rca.
-then you basicly repeate the process till you have all ur jacks taken care of..
like so..
- i like to twist them for a cleaner look...
-like so...
-then you can either add a ring terminal, or a male/female spade connector on the end.
like so..
i usually do spade connectors then run another ground wire off the back of the deck to hook into the spade..
- should look like this..
TAKE #2
same thing with the rca's in the back of the deck.
OK! now what i like to do is ground the chassis of the deck. to the chassis of the car via the extra spade connectors i have hanging off the back of the deck..
i allso ground threw the wire harness, but like to make a stout ground to these pioneer's..
i have yet to have any, ANY noise after doing this..
Thank you,
and Enjoy.
Not bad, I like the pics. If I were actually going to do something like this, I would have heat shrink the wire on then tech-flex for the better look.
this is just a general idea on how to do it... no need to one up me.. i can get this done in under 10min..
time is valuable to me so i have to do it fast. ( when installing and being that i am the only installer at my shop ). i never install and 2ch/4ch amp with a Pioneer deck without doing this...
now if i where to pull out the deck in my car... it looks allot better..
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
ultimate157
