Pioneer DEHP 8600
If the hu is P8600 try grounding the rca cables. Mine sounds a lot better after it. These Pioneers are known for their ground problems, but it's an easy fix. Just search this site for Pioneer grounding problem. Good luck
Yeah just ground what how do i ground the rca cables...it sounds like crap when you turn it up and the subs sound great in my car so yeah i dunno but yeah lemme know on how to ground the rca cables...
thanks alot man!
Just touch the outer metal part of the rca plug to the metal part that is grounded. Simple, if that works just salder it on. But you might wanna play with eq & ta before to see if that solves it
Interesting, should you just solder a small gauge wire to the outside and ground it?
If u mean solder wire to rca -- yes. if u mean solder the wire to the body of the hu -- no. in fact you can solder negative on rcas to the body of hu. i didn't even solder mine, just jammed the wire between male and female connectors. you can search one of my posts was about it.
disturbed_cbr
SLAMMIN
disturbed_cbr
George West, Texas
bratva5
michigan born
    May 14, 2026
michigan born
    May 14, 2026
