Pioneer Amp wire colours
  • 2
+ battery (yellow) ..........Ignition (red)............. ground (black)................remote(blue) .............the purple, green, white, and grey wires are for your speakers.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
simgarcha
simgarcha
Vancouver, BC, Canada
indosia
maylar
    Jun 2, 2024
    Jun 1, 2024
