Pioneer 9400 Problem
I have had this deck for about 3 months and this problems keeps getting worse. Whenever I am listening to a CD (MP3 or Normal) I can only get about 1 or 2 songs before I get an ERROR-11. This usually happens more often at higher volumes. If I take the CD out and put it back in, it will work again but only for a couple minutes before I get that error again. Anyone have any idea's what is happening? The CD's are not scratched and I have tried different CD's as well.
Thanks
Try to locate your manual and see troubleshooting. It would probably give you a list of error codes. If all else fail, send it in, that's what warranty is all about. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
on teh 9300, Error 11 means Dirty disk... so what's happening (assuming that the codesa re the same...) is that it is having trouble reading the disk... first off, try cleaning it... second off... CD-r's, or all cd's? if it's only with CD-r's, try a different brand... otehrwise, it might be a problem with the laser...
if the cds are clean...then get a laser cleaner thing...its a cd, but when you put it in, it spins, and its just a cd that cleans the laser, by being a little bit wider, meaning it touches the laser and cleans it.
- pe@ce
Chaotic Bliss
Chaotic Bliss
Toronto, ON
jer_stud56
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
