pattyweb
My system tells me error front speakers. I wonder if my gains are too low? I'm not being too aggressive in my gains so the system is not painfully loud at full volume. My amps are buried in the back so it's not that easy to play with the gains.
How loud does it get when it's doing the test? I can easily sit in my car while it's doing the front test. At it's loudest it's loud, but not painfully loud. Are you able to sit through your test?
Plus, another 'annoyance' with the 880PRS. It has two custom curves and you can set them, but when looping through the curves, it always shows you the same graphic. It would be nice if it actually showed the curve I programmed into it.
thanks!
thanks!
