SOLD ++++++++++ Phoenix Gold OUTLAW 1845 Limited Edition++++++++++ ONE BADASS AMP!
  • 5
Bricktop13
Selling My Phoenix Gold OUTLAW 1845 Limited Edition 1 of 1600 made
This is one Badass collectors piece
It's in really great shape, pulled it from my running system about 10 years ago and it has been sitting under my bed in a box ever since.
The Outlaws sold new for about $1500 - 15 years ago.
My Avatar pic is the actual amp.
As for feedback, and more pictures, You can check my feedback rating on Ebay: Item# 130423838717
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130423838717&ssPageName=STRK:MESELX:IT
The Max Wattage for this Amp if you bridge all the outputs is:
• 745 WRMS @ 4 ohms (13.8V) Or 700 WRMS @ 2 ohms (13.8V)
OUTLAW Specs
• Gold Plated 2 Layer, 2 ounce Copper G10 Glass-Epoxy Printed Circuit Board
• Dual power inputs
• High-Current Triple-Darlington Output Stage design
• Tri-Linear output capacity (simultaneous stereo & bridged mono operation)
• Stereo 12dB per octave, continuously variable crossover from 30 to 500Hz
• Selectable HP, LP or Full Range for the internal amplifier and HP or LP for the external output
• Adjustable High-Q Bass EQ (0 to + 12dB) @ 45Hz
• Pulse width Modulated MOSFET Switching Power Supply
• Stable into 1 ohm stereo or 2 ohm mono loads
• Variable input sensitivity (200mV to 2V)
• Thermal Overload Protection
• Superior muting circuitry assures no turn on / off noise
• Optically isolated power supply
• VI limiting circuitry with over-current LED
• Low RFI/EMI design
• Bridgeable Outputs
• Extensive burn-in and QC testing for the ultimate in reliability
• Made in the good ol' USA
http://www.caraudio.com/forum/car-audio-classifieds/487146-%5Bb%5Dphoenix-gold-outlaw-1845-limited-edition%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D-%24799-obo%5B-b%5D.html
Output Power per Channel-Both Channels Driven
4 ohm @ 12/13.8 VDC
M50......50/80 WRMS
M100....100/185 WRMS
2 ohm @ 12/13.8 VDC
M50......100/120 WRMS
M100.....200/230 WRMS
Bridged into 4 ohm @ 13.8 VDC
M50......245 WRMS
M100.....500 WRMS
THD at rated power 4 ohms....0.05%
SMPTE at rated power 4 ohms
Crossover Frequencies
30Hz to 600Hz
Crossover Slopes
12dB per Octave
Bass EQ
0 to + 12dB @ 45Hz
Input Sensitivity
200mV to 2 Volts
Case Dimensions
29.25"L x 10.63"W x 2.0"H
Dimensions with Flanges and Terminal Blocks
29.25"L x 11.63"W x 2.0"H
M100 section:
2 x 100W @ 4 ohms (12.0V)
2 x 185W @ 4 ohms (13.8V)
2 x 200W @ 2 ohms (12.0V)
2 x 230W @ 2 ohms (13.8V)
1 x 500W @ 4 ohms bridged (13.8V)
Fuse: 40A (4 ohms) or 70A (2 ohms)
M50 section:
ebay auction has been removed?
Nice amp though. I always wanted one of these limited edition PG amps (Rt. 66, Frank-amp'n-stein, etc.). Sadly they're pretty obsolete now, but still...
Dunno what your eBay fb is but if it isn't in the hundreds don't expect a fair price.
I meant you should write your username on a piece of paper and post it with the pictures of the amp.
I see what you mean. The amp and my camera are at home, so I won't be able to do that until I get home later on tonight. Would that be ok?
The link should work now, if it doesn't the item # 130423838717 still does.
I wouldn't call them obsolete, they just don't have all the bells & whistles of today's technology. They were definitely way ahead of their time when they came out.
Not knocking the amp, both amps in the heatsink are very very nice and as a whole it's super clean. There's just more power/features in a smaller package available these days.
Techically you're not even supposed to list eBay auctions here I believe and I wasn't even saying anything since it's such a sexy old school piece.
Anyway, listing looks good (and I am a high volume seller on eBay) I think you might get a fair price. GLWS ... I bet you'll regret selling it.
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
708
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
Bricktop13
Bricktop13
Northern Virginia
Bricktop13
audiobaun
    May 19, 2024
    May 19, 2024
