Passive Radiators
  • 5
had some home audio ones YEARS ago the box only had a 6.5" woofer but coupled with a 10" passive had an amazing amount of output, and if your wondering I thought it couldnt be doing all that much either until I removed it from the situation and was amazingly disappointed in the 6.5 alone. From what I could tell it just moved equal/opposite of the "powered" driver but I know there are ones now a days that can be tuned to your liking.
they act just like a port they can be tuned by changing the weight added to the cone.
they save airspace since they arent very deep and allow you more design flexibility.
general rule of thumb is if you have a 10" sub u need a 12" radiator but this is not always necessary as long as the radiator can displace the same amount of air or more than the sub which is why boston's radiators are the same size as the speakers they are matched with.
personal experience they work good for smaller systems up to about the 145db range after that i cant say ive ever seen a passive radiator system get louder than that.
biggest downside to the radiators is generally their price
So say you have a 12inch subwoofer and you get a 15inch radiator would the output be higher with the radiator specifically on the lows.
say you have a 12 inch sub and u get a 12 inch radiator with equal xmax and then you get a 15inch radiator with 3/4 xmax is the sound going to be different of they are both tuned to say 34hz?
quick answer is no
the passive radiator is going to displace the exact same amout of air as the sub driving it.
the reason people recommend larger radiators is because they dont have to excurt as much to equal the same displacement as the sub driving it and generally lower x-max radiators are cheaper
you would tune a radiator just like a port but instead of adding port length u add weight
From my readings a passive radiator greatly extends the frequency response of the woofers. Is there any output achieved by the radiator itself or is the only purpose of it frequency control?
it's exactly like a port, nothing more nothing less. I can't believe people in this hobby don't know how a port works.
I know how a port works and from what I have been reading it says it achieves greater response.
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
772
Yep. It would be a little over 3 wired in series, but that’s fine.
828
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
murph
Low for Life
murph
Richmond,VA
    May 16, 2024
    May 16, 2024
