Solo x 18 owners
Spldecendant
Ny
What's the magic box size they like after displacement on about 4500w rms? I just got 2 solo x 18's the area in the back of my sub is 49w by 22.5h and 40d but I would need to be ported so I would say I can go like 37 deep and I'm going to be running a dc9k to 2 of them. I was thinking 7.5 cubic ft each but was unsure
They will never take that power on music. I have heard a ton of Solo Xs and know a bunch of people who own/have owned them and they do maybe 3k each daily TOPS. They just don't have the cooling.
7.5 Is close enough. I figure for 7.145 cubes to control a 30Hz tuning and about 5.614 each for around a 35Hz tuning (port characteristics obviously a factor also-but will not be given). With a port area smaller than the effective surface area of the cones, you should get great output keeping them under or around 7.5 each as mentioned. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yea I rethought how much power I wanna run probley like a dc 7.5k I have an ia40.1 right now for the brake in. Would 4 6inch aero ports facing the hatch be my best bet? Enough port area or 8inch areos
I have also owned a couple. I would say 8 cube on the small side per woofer. When I used them they did well tuned @ 40hz, they really quaked in the 50-55hz range. They have about the same cone area as a pair of round 15's so think about what port/volume would be adequate for that.
I played one (never had room for more than 1, though I owned 3 at one point) on Sundown 3K and it held up to that well for music. On a pair of 3K's the got stinky very very quickly. Really if you are abusive with them I'm confident you could break them at 2500W each pretty easily.
I have 2 18's of them and at max the cargo area in my escalade is 49 wide 22.5h and like 37 deep I wanted to tune to like 35hz
This is for daily use and what you think I should tune to I still wanna be able to play lows without having to worrie about blowing the sub.......u think I be safe to play the 2 on the dc 7.5k voltage is not gonna drop below 14.5 and everything is gonna be set with the smd dd-1
If you use more of the port volume to control the response, you can cut down on compression volume and control the excursion more also, so you get a better balance between the power limitations and mechanical limitations if you are going daily. Just a thought. The volume will depend more on the entire design and limits. Not going against the others, just giving an option that will work well in your situation. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Spldecendant
Spldecendant
Ny
Moble Enclosurs
