Lol. Yea same idea pretty much. I wouldn't suggest using a condom, knew a kid in highschool who did that and it unraveled in his pants and he got covered in **** hahaHeres what you do,first do not spend money on any shit from a shop,they can tell,get some real clean **** from a guy put it in a condom,before you go warm it up for 5-10 secs.put it between your balls and your thigh so it get's body temp. Get a safety pin put in in your shoe or something because some place will have you turn your pocket inside out orfasten it on your underwear(wear some tight underwear/briefs)if the temperature is between 96 and 98 your good.
Sourdeez beat me to it,but use a condom and keep it close to your body it when even out the temp.
Tht requires logic....something op is lackinghow about, if you know you are going to be tested for a job i'm sure you need....DON'T SMOKE WEED. i know it sounds simple, but what is more important, hi as a giraffe's a$$ or a job? i used to smoke every day, then came responsibilities i had to quit. yeah i miss it sometimes, then i go to work.
All good ideas but I am telling you when u fail it will be due to the temp. The pee has to be your INTERNAL body temp. Taping to your leg will warm it up that I have no doubt. Is the chance for failure very very high yes it is. The places I have taken test at over the years for promotions and whatnot got their stuff together. Empty all pockets, raise pant legs, men must stand while giving sample (unless you have some form of legit medical reason) no they can’t see u there is a door but it is not tall nor long so there is zero chance u could squat without getting noticed and u have a time limit and right inside the stall they have a window (metal window) that opens as soon as your done and it is taken right that sec by the tech and the temp range it has to be in is very small we are talking plus or minus a degree or two. Good luck is all I can say maybe they will send u to a crap clinic that don’t do their jobs as they should. You want the job then you do it the right way and swallow your pride and take one up the hole for a job. But if your clinic is anything like the ones down here that method is useless as you are unable to sit and you just don’t have the time. Best wishes man.
