Passing drug test
One full proof way and thats to shove a condom full of clean p i s s (make sure its male p i s s ) and shove it up ur a s s. That will wrk will it be fun well to some maybe but in general no its gonna blow but u do what u gotta do,
if your pee is too diluted they will test her a lower content compared to the standard. And depending on what type of company it is, they may have a contract with a lab already and they actually send the tests off. my company does hair testing for EVERY employee, even the janitor. that **** goes back years.
either get sum p iss frum a home boy that dont smoke and u kan use a condom or a lil bottle tape it to ur swangaz to keep temp or go to a head shop and buy sum synthetic urin the one i use is quick fix and its about 20$ for the lil kit and the bottle they give u in it has a tempature strip so u kan make shur its body temp and trust me it works but tape it to ur shiznit and ur good to go they usually make u empty ur pockets and send u to a bathroom and make u p iss what ever u do make shure u got atleast 2oz i used to work in the chemical plants in houston and quick fix worked for me every time its even lab safe good luck bro
oh ps smoke weed every day
also i for got u can use CERTO its used to make jelly kinda like sure gel but any ways this is more kinda hit or miss it u do it right it works ok for test strips i used to do it when i was on probation when i was like 16 but u get a 32oz gatoraid and a box of certo take only 1 of the certo pouches and empty it into the gatoraid and shake it up drink it and then drink a **** load of water **** 1 time then go take ur **** test but it has to be done bout an hour or two befor ur test it might work but like i said thats a hit or miss one it was 11 yrs ago when i used to do it now i just smoke and dont worry bout it i like the quick fix system
99% of those BS scamming clean u out drinks are just that BS. If u want man up and do it the legit way then forget about it. Stick ***** up ur a s s its that simple. add pee to condom tie it off (be sure its water tight) grab a tampon cut the string off tie around knot u made in condom and let the string hang out so u can easily get it poke it with a nail then but back in pocket. It will wrk and u will pass now the question is how bad do u want this job???
rangerboy101
Dr. Subwoofer
rangerboy101
Winchester, Va
mazdakid
