Particle board for speaker rings....
  • 7
whitemdx
SoCal
I am waiting for all my stuff to come in and purchasing the little stuff locally..Local home depot only have 4'x8' MDF boards and I don't need nearly that much. I building a fiberglass box for 1 12" AA arsenal and wondering if it will be fine if i used particle board for the front piece of the box and the rest will be fiberglass? Or other alternative type of woods beside MDF?
particle board is fine, it will soak up resin alot more than MDF actually //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
For a speaker ring it's fine, but is a little harder to cut then mdf. my router zips through mdf, but drags on particle board.
I have a suggestion. Places like home depot and lowes, whatever else you have NORMALLY have MDF shelving which comes in different sizes. check that out, they have 3'x16", 16"x1', etc, check that out first, theyre like 3 bucks a sheet for that
particle board is probably more ideal anyways, lighter and absorbes resin better which is ideal for rings because you want to fuse the material to the rings unless your rabbetting the edges.
Similar to the Power Acoustik A1800db / A2400db / a3000db / OV1-5500D amps, Planet Audio BB2400, Soundstream PCA2000d, and several others that use...
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
692
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
513
690
whitemdx
whitemdx
SoCal
nVRuckus
