PA doesn't say RMS at 1 ohm?
who gives a **** what it says? All planet amp bench tests i have seen are above the 'max' rating at under 13v
my old planet put put 1286@12.9v that was a couple years ago (p1250d model)
smokealot, um, you smoke too much.
the amp obviously has a root mean squared power rating at 1 ohm if it is putting out any power at all. unless you are saying it randomly puts out different wattages everytime you use it, from 1 to eleventy billion watts. even then you could average a rms out of it.
back to the discussion at hand....... PA, although good for the money ussually, is not up there with higher end brands that are not affraid to lists an amps max rms....... in order to sell that PA they list a majic # that that can under the right conditions can put out. but even the best amps in the world dont always put out full power due to inefficency. that amp more or less would put out 1000w rm at 1 ohm... but to sell it better they rate it's max at 1250w....... get the picture
guys this is a forum not a sandbox...grow the fuk up
He says that he benched his and got over the stated "Max power" at one ohm.
I guess i need to look for some mroe bench tests, and see what i can figured out. I just like the idea of getting that much power for $150.
i have a birthsheet that says my VX3002 does exactly what its rated for, at 13.0 volts
kuijo
kuijo
TX
Acidburn
