Output Transistors on Kenwood Amp Kac-9105D
leamprotan
Canada
Hey Does anyone know the part number of the output transistors on a kenwood kac-9105d 1800w amp? I wasnt getting any output so I opened up my amp to find scorched transistors there are 5 in parallel and I was looking to order 5 new ones to replace it and see if it would once again work. The only problem is I can't figure out the part number off these little transitors I know they are ST transistors.
Could someone help me out with a link to buy new ones or the part # so I can order them?
The ones that are blown open look like they may be power supply fets and not output fets. Your pics aren't clear enough for me to see the part numbers on them though. Try wiping a little bit of that white heatsink compound behind the fets on the face of one of them and then wipe it back off. It should help you make out the numbers on the face of the transistor. Try that and post or PM me everything you see on one of those five fets(actually there is most likely six. The one just to the left of the five in that group is most likely also a power supply fet)
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
leamprotan
leamprotan
Canada
Spooney
    May 12, 2024
Brendon Jenness
    May 11, 2024
