Orion HCCA 2100 Specs
  • 2
it is rated at 2 X 100 at 12 volts but will run 800 watts at 2 ohm mono. I wouldnt run it any lower because it is a high current amp and heat up very quickly and shut off. Sure it will run half ohm but not for verry long.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
orion4me
orion4me
East Texas
EPanther99
    Jun 1, 2024
    May 31, 2024
