Orion hcca 10's, enclosure suggestions
  • 5
they love space...for spl only, orion strongly advises against a big box for daily, if i rmember correctly 2.4 cubes for the new gen hcca 10's for spl and 1.8 for daily, and they like low tuning orione seemed to want ppl to keep the tuning at 31 in most applications
Right on, thanks. I'll probably be building this next week. so this is an spl only sub?
Not at all, it can dig quite low. I think of "spl only" as a high fs sub with a ton of motor force made just to burp loudly. The HCCA can slam down low in the right box.
I'll you know how this turns out. Being driven my a rockford bd1000 i dont they'll reach full potential. We'll see.
Definitely not with just 1kw going to the pair. Unless you plan on upgrading to at least 3kw for the pair, I'd up box size to 4ft^3.
I would just run 1 on 1k... I had 1 12 on 1800 (my electrical wasnt that great though, so probably closer to 1200), and it wanted much more power! I think you would like 1 on the 1k, rather than 2. Or less you plan on upgrading... Some people have ran around 2500 watts daily on them.
Well going to do just one, considering it's going in a little hatchback honda, for weight purposes. So you guys are saying 2cu/ft? I have the space so I'll probably end up doing that.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
913
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
supermaxx123
supermaxx123
I.E.
supermaxx123
SPLBassJunkie
    May 21, 2024
    May 20, 2024
