Orion Cobalt Series CS500.5 5 Channel Amplifier
dgaf
Swollen Member
755
727, FL
Variable low pass crossover 30Hz to 2.5kHz
XBC12 Bass Boost
8 gauge power/ground
16 gauge speaker
High efficiency heatsink
PWM power supply
100% QC Tested
4-Ch x 50 Watts & 1-Ch x 150 Watts @ 4 Ohms
4-Ch x 70 Watts & 1-Ch x 300 Watts @ 2 Ohms
Signal Processing: Three continuously variable high pass (50Hz-1kHz) or low pass 30Hz-250Hz
Fuse Size: (2)40 AMP ATC
Dimensions: 15.7" x 10.1" x 2"
Some minor wear, a few little scratches, and dusty, but overall good.
$140 but open to trades.
$10 for shipping
I'm also [downwiththekrown] on eBay with 300+ positive feedback
i'm actually looking for a few things, i just got a 1997 f150, so i'm trying to build up the system a bit at a time.
right now, it's only got a orion 300d amp in there, hooked up to a blown 12" type r.
so i would like a 12" sub, that would be good getting 300w at 1 ohm... that's the main thing that would keep me going till i can afford the bigger ****.
but, down the line i'll be looking for a alternator for a 97 f150, a bigger amp (2000-3000w mono) a 12 or 15" sub (2000-3000w) and a battery or two... obviously any of those would include cash on my end...
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
dgaf
Swollen Member
dgaf
727, FL
dgaf
