Orion 2500d problem
Weece
WEEEEEEEEEEEEEEEEEEEEEECE
Well the problem is i have to turn the gain on the amp 3/4 up before i even get any output from it. I just dont think i should have to turn the gain up on a 2500 watt amp to power a single 15" xxx.....so just wondering if it is hurting the amp to run the gain almost all the way up like this? It seems to get alot hotter then it should to....so just wondering if any of u guys have experienced this. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Did you use 2 grounds and 2 +'s ? My friend had only one of each and thats what happened. How many amps is your alt? I have an orion 2500d to my 15xxx and i have it like at 1/4 and i cant turn it up no more, in a 02 blazer stock alt. I usually dont go lower than 13v.
//content.invisioncic.com/y282845/emoticons/imdaman.gif.bc6c552e19aa4ad8c47461144f40eb1a.gif//content.invisioncic.com/y282845/emoticons/noevil.gif.0723d47b61c306c6d554fb6555014096.gif
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif BIA BIA T CH BIA BIA T C H
See thats what i dont get.....you cant even turn urs up past 1/4 and i have to turn mine almost all the way up to get output. But im not sure how many amps my alternator cause i lost my book....lol but its on a 2001 yukon. I get mine to go about 11-12 volts also......so im guessing its my alternator i just wanna get some input before i go out and buy a new Alt.
wow, i never been down to 11 volts.. today i hit 12v but thats cuz i had it at 30/40 and i was acting crazy and just blasting it.
well running an Orion 2500d on a stock electrical system will get ya there //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif .
Mine is on ALL stock, not even big3 done and its good.
Well **** thats what i dont get......i dont see why i have to crank the gain so much.....oh well about to replace the Alternator and see where that gets me. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
idk if ur head unit has amp control or not but u could check that.
Its not ur alt if ur getting output from it lights would usually be a problem not gain, IMO..
But make sure u hae it wired correctly it might be out of phase, u know +to- vice versa.
last thing i can think of is, u have ur sub wired wrong. The xxx has alot of dam wiri9ng check Re's website and make sure its connected so u have 2 or 1 ohm, or just get the dmm out and test it to the sub.
Weece
Weece
Fort Smith, Ar
CRXBMPN
