BassAddictJ
definitly play with amp settings
but its all installdependant in ur car and his....if he hasa tiny *** hatchback then i can see where his system would sounds remarkable good and make a mediocre install with an orion 2500d look shasty. besides install the biggest factor is the box, ported boxes are tricky because a realllly well built ported box built to specs will sound amazing and a prefab or poorly built ported box will sound so horrible it'llbe like night and day. was ur box prefabricated? double check the ohm config of the subs, could be accidentally wired to 4 ohms (whi is still a good amount of power out of that thing)...for some reason or another you're not getting alot of out the amp and it's not JUST a new alt upgrade to fix type deal. make sure ur intall and box are as good as possible
