Options of subs with my Ohm rating
I'm a bit confused about this
So I have a MTX MXA4002 amp that does
100 watts RMS x 2 channels at 4 Ohms
or
200 watts RMS x 2 channels at 2 Ohms
or
400 watts RMS x 1 channel (bridged) at 4 Ohms
Now I currently have a 400 watts sub 4 ohm and was lookiing at upgrading but 4 ohm selection isn't big.
What would be recommended. Can I somehow wire a dvc 2 Ohm to make it like, 4 Ohm or how does that all work? Or am I stuck with searching for only 4 Ohm subs, which there isn't a whole lot.
What kind of music do you listen to, what kind of box do you plan on using and what kind of vehicle do you have?
If you have a sealed box then using a different sub won't be upgrading much of anything. The sound quality might vary between the two but at that power level you won't gain any more output than maybe a few tenths of a decibel which is inaudible.
You can wire a dvc 2 ohm sub to either 4 or 1 ohm.
I listen to Rap, hip hop and EDM like music. I'm about to try a ported and sealed box. It's a 06 tucson hyundai but I'm changing cars soon.
But, anything else wouldn't be better than a 60$ sub. I mean, it the watts all that matter in a sub itself (not talking about enclosure and other), it what I feel like you're saying here.
Oh wow throw that thing in the garbage! When you are starting with a sub that bad then the opportunity is much greater lol.
There are plenty of nice subs to choose from here
Thanks for the link I'm Canada though so selection isn't as good and the price but I'll look at the link for suggestion
If you are wanting to keep the same amp bridged at 4 ohms/400w then look for subs that are dvc 2 ohm or svc 4 ohm.
Oh okok so I could get a 400 watts RMS dual voice coil 2 ohm subwoofer and wire it to 4 Ohms and push 400 watts to it from my amp? This actually opens a lot of option that I didn't knew.
There are plenty of options out there and when you find the right one here is how to wire it:
Spokey there is people at DIYMA that will remote in for 20 or 25 bucks to tune it right. Well worth from the people i've talked to on it.
10
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
950
Just make sure they are not the type that "identify" as female.
41
5K
For best results you'll really want to be able to see the cones from your listening position. Firing some 6x9s down at your feet or into the...
MidnightNarwhal
Gatineau QC
shredder2
    May 23, 2024
    May 22, 2024
