Optima Bluetop + 200A Alt + Deka +3000W=FAIL!!
snb778
blaugh!!!!
Mod Delete Thread Please
Done with the car folks....
well.... i've come to the conclusion that its just not enough power after mannnnnnnnnnnnnnnnnny hours of testing.
im done
MX3000.1
200A alt
Bluetop up front
Deka in back
big 3 done
all connections soldered
checked all fuses and tested/replaced just in case
all ground grinded down, BOLTED to frame
Voltage stays at 14 up to 80% volume, then drops to 12.2 on full tilt..
Headlights DON'T dim much though...... weird
Have you clamped the alt? And yes the Blue top is NOT a good audio battery.
got the one with the same specs as the Yellowtop
got it clamped... did fine @200A
im kinda F-ed with the under hood batt because my terminals are opposite of 99% of cars out there, which is why I went with the double top post bluetop
you could always change your stock posts.
I've had better output from a $90 Duralast than the last Blue Top i bought. What type of car and what amp?
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
Lakota
