Opinions on this setup?
I'll prob stick to the 2 10's and use the money I would pay for the fab work towards the subs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
DC and SSA (along with Sundown, Fi, AQ, Incriminator Audio, and others) are considered internet brands. Not very mainstream. But pretty high quality. People here will attest to this. For example, I run an AQ1200d to a DC Level 4 12" in my vehicle. Amp stays cool and does its job well. The Level 4 is a wonderul SQL woofer. A local shop wanted a demo and said they'd take it over a W7 (JL, Hertz/Audison dealer). Which is about twice the price.
These subs are all handmade and usually easily recone-able.
They get you a great product more designed towards what you want, at a lesser price.
Also, PSI can build you a sub from scratch to accomplish about anything you want.
-Fi SSD is 800rms each. Would stretch his power limits and make the charging system crucial. So I disagree.
-Audiopulse is expensive (though great) and throws budget out the window.
-Havent heard the Mach 5 so no opinion there.
DC and SSA (along with Sundown' date=' Fi, AQ, Incriminator Audio, and others) are considered internet brands. Not very mainstream. But pretty high quality. [/quote']
Assuming they were going on the same scale, where would they rate up against name brands like RF, MTX, Pio, Audiobahn, etc?
i would go with dcon in the end then
with this amp, co designed by zed, its 95 percent effecient with only a 60 amp draw, best amps they ever made easily and really small 2 be hidden, also look at the distortion, very clean sound, the a7 its older brother is my fav amp ever. and its direct from cadence
Cadence A5+HC 600 Watt Competition Mono Block Amplifier - eBay (item 290368818833 end time Jun-08-10 10:47:34 PDT)
Rated RMS Power: 25 Watts
300 Watts RMS Power @ 4 Ohm Mono
600 Watts RMS Power @ 2 Ohm Mono
Frequency Response: 10Hz – 500Hz
Input Sensitivity Range: 200mV – 8 V
Input Impedance: 22K ohms
Total Harmonic Distortion:
Signal to Noise Ratio: 60dB
Damping Factor @ 100Hz: >200
Narrow “Q” Parametric Bass Equalizer: +/- 18dB @ 45Hz
Variable Low Pass Crossover: 24dB per Octave 50Hz – 250Hz
Subsonic Variable High Pass Crossover: 18dB per Octave 20Hz – 50Hz
Output Impedance: 2 – 8 ohms
60 Amp Fuse Maximum
Digital Amplifier Efficiency: >95%
Dimensions (L x W x H): 10” x 10” x 2.65”
I should also point out the obvious.
The Mobile Monitor subs that you originally linked aren't terrible. I just thought you were sold on the MB Quart DSC1500.1 and thought the amp would be better suited to a more "impressive" pair of subwoofers...
compared to other brands suggested, the Polks may be a bit pricier, but Polk does make some great SQ products. All items suggested are also very good products, and the OP should feel comfortable running any of those that have been suggested. As a whole, the "interenet" brands are now better than the mainstream brands these days
jgruberman
jgruberman
North Dallas, TX
mclerico83
