Opinions on this box
Lowflyin
Sit on my face, B*tch
1,149
FU JOSE, PA
36w X 15.75H X 27D Box with a port that is 25.5W X 3.5H X 27.9D for 35hz. is this correct? Im looking for 5.5 cuft net at 35hz and 89 sq inches of port. take into account also .28 cu ft for sub displacement/.
lol no just bump someone will eventually come in and help ya out...but dude just use the calculators, may take you a few minutes to figure out how to use them but they are pretty easy. I'd help you but my experience is prob about as much as yours.
You're close enough. Considering no bracing, I got ~5.25ft^3 with a tuning just under 36hz. With the port needing to be 28" long, I'm assuming you can just use the depth of the box (25.5") and put a 45 in the back corner to turn the port that last bit.
7.25ft^3 before displacements
27"x4.25"x25.5"(interior depth of box) = 1.7ft^3 port displacement
sub displacement per your info: .28ft^3
~5.25ft^3 after sub and port displacements.
Thanks Ryan, this sound alright for an hdc 318, I have 3000w for it so a little smaller box may be ok. Andrew mast said he has had good results between 5-6 cu ft so I went off that
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
JL RD1500.1 does rated power @1 or 2 ohms, Does 1800 to 1900 watts in tests I've seen.. Designed buy a guy who designed old school PPI and Xtant...
13
Lowflyin
Lowflyin
FU JOSE, PA
Lowflyin
