opinions on probox boxes
Lanzar OPTI1533D Optidrive 15 (single) (3000 actual RMS) when you say goals like what are some different ways i could go
@Buck ; designed my box for a single 15" L7 Kicker. its 4.25cubes @ 33hz. His price for blueprints was next to free. hes pretty swamped to turn around time may play a factor, but a great designer :)
goals meaning, what kind of response are you looking for from your sub stage?
There is a list of things you will need to get a quote for most of the good designers/builders.
A rough idea would be needing around 4ft3 net give or take a bit.
everybody in my family dose construction so i was thinking about building it myself is there a calculator for box designs online (so i can get the perfect measurements)
Basically do you wanna dominate the low end? Do you want people to hurt with the 40 hz range? Do you want a mix of good lows and upper range? Or are you strictly going for numbers on the meter?
Those are some goals for ya.
PIMPSLAPN
PIMPSLAPN
MI
PIMPSLAPN
