opinions on my planned/semi installed setup
ivrex
Docta Shocka!!!
ok well here we go
so far already installed i have my Pioneer Premier Deh-770mp Headunit linked to iPod.
front stage is Crystal Mobile Sound SSX coaxials 6.5" and matching 6x9s for rear stage.
i PLAN to amp the 4 speakers with the Crystal CAM 110.4 4ch amp
http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogno=CAM1104
i already own a Diamond Audio D6 12" dual 4ohm vc sub. i also PLAN to replace my once-was noob audiobahn amp with the Diamond Audio D3 800.1 class D monoblock
http://www.sonicelectronix.com/item_7791.html
there will also be a 1.0 farad stiffening cap which i already own
and right now i am in the beginning of building a custom sealed 1.0 cuft enclosure for the D6 with amp mount
this will all be wired up with knukonceptz wiring
so what do you all think?
these are ALL my 1st generation audio purchases except the DA amp which will be replacing the Abahn. but the HU, speakers, sub, and speaker amp would be a 1st for me
im open to criticism unless your an ******* about it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
but im sure i dont have to worry about that
thnx for being the only one nice enough to respnd //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
anyone else?
sounds nice. the only things i would change is the cap., you don't need one. and i would change the front speakers to a set of comp.s and run them off a 2-channel and leave the hu to run the rears. but that's all personal preference but does look good.
if you cap looks cool i would leave it just for style. also i like the digital volts reading on most of them.
i think that sounds like a good set up. overall i think you'll be happy in the end. and depending on how custom you wanna get, getting comps in the front would be good for sound. good luck
yeah i wanted to get comps in the front but that would have meant custom mounting the tweets, so i decided to leave that for my next setup bc these were the 1st speakers ive installed. ive gotten suggestions to skip out on the cap nd get a yellowtop but ill barely be able to afford to finish this system up for now. but it wont hurt me to use and and as noviceguru said, it looks cool. soo ill have it mounted on once side of the sub with the amp on the other.
well it seems like ive managed to do a good job on my 1st setup. i just cant wait till its done
ivrex
Docta Shocka!!!
ivrex
N-town, PA
ivrex
michigan born
    May 14, 2026
michigan born
    May 14, 2026
