OLD SKOOL! Clarion DPX 1000.2 Best budget amp ever?
Clarion DPX1000.2
← home
2 x 175W @ 4 ohms (0.05% THD)
2 x 250W @ 4 ohms (
2 x 330W @ 2 ohms (0.5% THD)
2 x 450W @ 2 ohms (
2 x 500W @ 1 ohm (
1 x 1000W @ 2 ohms bridged (
Fuse: 3 x 30A
Same board as:
. Arc 1500DR
Beefy!
http://ampguts.realmofexcursion.com/Clarion_DPX1000.2/
And your answer is right there in black an white. Wire each sub on one channel at 2 ohms and they will see 450w apiece.
Sorry but I dont **** all about wiring off the top of my head. I saw it said 2 X450 @ 2ohms, but it also says 330W @ 2ohms
Doesnt make sense to me how you say it though, because the OHm symbol on the amp over each chanel is a 1ohm symbol....
Im lost here
Im lost here
The 1 ohm designation ober the amp output probably just means it's 1 ohm stable. If you re-read the specs, you'll see that the difference in power levels at 2 ohms is because of a difference in the amount of thermal distortion you allow. But sub-1% is fine for a sub, so you can go ahead and set it up for 450w per channel.
I'll make an ms paint drawing to show what it means, I dont wanna **** shit up more than i already have. Im gonna buy another amp tomorro but itll take a while to get to me, this is gonna replace a busted amp for temp
I know what you're talking about. I saw it on the ampguts pics. It just means it's one ohm stable on each channel
Oh sweet your already in here lol, ok I really dont get what these dual chanels mean and what not but is there anyway to wire it without me taking the drivers out of my box (itll be a hue pain)
I basically have the 2 woofers I need to amp wired with all there +'s together and all -'s together with a POS and NEG coming out of the back of the box. Anyway to make it work with just these 2 wires?
I just bought a Visonik 4000D amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The only way that will work is if you don't mind each sub only seeing 250w for a little while. Then you can just hook those wires up to one channel and leave the other channel alone. I don't think these amps are bridgeable, so the only way to hook them up would be to pull them and re wire or run them on a single channel.
Unless you have a terminal cup on your box that you can remove and just pull the wires through to wire the subs down to 4 ohms (series-parallel). Then you could get 900w bridged at 4 ohms. That should work
WOT
Banned
WOT
Toronto,CANADA
Hintzyboy
