There is nothing in them, Thats why im asking. I think ill just hook it up and see if i can power it up with just one power/ground wire.Ok im sorry I got you now. Are they both 4 gauge connections? Or 2 gauge?
It should work with just the one side.Nice amp you got there, the only reson for the two inputs is to make sure enough current can flow through.I believe those are 4ga which should be fine, but I would suggest running dual lines to it.
what exactly will happen if they are wired in the opposite side??yo, i have the same amp and you only need to use one of the terminals to get it to work, just make sure if u use the power on the left you use the ground on the left too and vice versa for the right hand side. And they are 8 gauge term's NOT 4 gauge, dont ask me why.
