Old school punch 800s2 question..
Im a lil lost, does the amp have more than one power and ground connection? Or are you asking should you make a second run of power and ground?
Yes, It has 2 powers, and 2 grounds. Do i need to use both?
Ok im sorry I got you now. Are they both 4 gauge connections? Or 2 gauge?
There is nothing in them, Thats why im asking. I think ill just hook it up and see if i can power it up with just one power/ground wire.
It should work with just the one side.
Nice amp you got there, the only reson for the two inputs is to make sure enough current can flow through.I believe those are 4ga which should be fine, but I would suggest running dual lines to it.
It should work with just the one side.Nice amp you got there, the only reson for the two inputs is to make sure enough current can flow through.I believe those are 4ga which should be fine, but I would suggest running dual lines to it.
Never knew, I had a 250a and a 500a but the 800a2 was a lil out of my budget back then lol. Learn something new everyday.
Agreed though, very nice amps, still miss mine sometimes.
How would i go about this 2nd line? Another fuse straight from the battery? or can i put like a battery in my trunk too and that will help?
yo, i have the same amp and you only need to use one of the terminals to get it to work, just make sure if u use the power on the left you use the ground on the left too and vice versa for the right hand side. And they are 8 gauge term's NOT 4 gauge, dont ask me why.
what exactly will happen if they are wired in the opposite side??
94civik
94civik
MN
94civik
vegang
vegang
