Ok Im probally going to buy some audiocontrol products, Im looking to get a Epic 160 for my bass control and a Four.1 Audio Control EQ, now on this link
https://rs6.eporia.com/pv_obj_cache/pv_obj_id_93217156C8306FA7F13AC90F58358CBACD270600/filename/Restore_iPod_Bass%20Systems.pdf
it shows basically my setup, I have a sub amp, front stage amp, and a rear stage amp, ok so what design should I go with, should I do design 1 and do the epic before the eq, would that help even the midrange bass, or should I go with design 2 and have it after the eq, which It shows I would need the electronic crossover 6XS also, would I need that? Well the FOUR.1 eq doesnt have a sub input, or output, just front high pass and rear high pass so im not sure if I could conect the 2, would I just take the front pre out off the deck and plug into the main input on the eq? also the epic 160 only has 1 input and 1 output so i figured i would take the sub out put on my deck and plug it into the epic 160 then from that run to the sub in on the 6XS then to my sub amp
