Ok how do I wire these 2 amps?
mgcauctions09
alabama
I have 2 ap30001d amps. Got 1 power,1 ground to each amp. With the remote wires can I jump 2 wires (1 from each audiopipe to my mids and high amp?)
Also I have a set of rcas coming from sub output on my headunit. How do I send a signal to my other amp? I only have 1 sub out?????
Yes you can just jump the remote wire.
They're both sub amps correct? Well you can either buy Y-Splitters for the RCA cables, or the amp should have an RCA in as well as an RCA out, so you would just need a set of RCA cables to go from the out of the first amp, to the in of the second amp.
You take the sub RCA, which has a male end on it, and plug the female single end of the Y splitter into that. The Y splitter RCA will have a female end on the single side, and 2 male ends on the end that has the split in it. Just use it to get 2 RCA ends and plug one into each amp.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
106
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
565
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
908
mgcauctions09
mgcauctions09
alabama
mgcauctions09
    May 18, 2024
    May 18, 2024
