Ok how do I wire these 2 amps?
mgcauctions09
I have 2 ap30001d amps. Got 1 power,1 ground to each amp. With the remote wires can I jump 2 wires (1 from each audiopipe to my mids and high amp?)
Also I have a set of rcas coming from sub output on my headunit. How do I send a signal to my other amp? I only have 1 sub out?????
Yes you can just jump the remote wire.
They're both sub amps correct? Well you can either buy Y-Splitters for the RCA cables, or the amp should have an RCA in as well as an RCA out, so you would just need a set of RCA cables to go from the out of the first amp, to the in of the second amp.
You take the sub RCA, which has a male end on it, and plug the female single end of the Y splitter into that. The Y splitter RCA will have a female end on the single side, and 2 male ends on the end that has the split in it. Just use it to get 2 RCA ends and plug one into each amp.
mgcauctions09
mgcauctions09
alabama
mgcauctions09
