ohm
  • 2
The difference between 2ohm and 4ohm subs is the amount of electrical resistance they are manufactured for. The main reason for the different ratings is for wiring flexability. most car audio is 4ohm. The different ohm ratings can allow 4 subs to be hooked up to one amplifier, or one sub to an amplifier for maximum performance.
It also lowers the amps efficiency and raises the current draw.
579
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
388
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
boogieman909
boogieman909
philippines
natem33
    May 24, 2024
