Ohm Readings
NINYO
I gotta PSW912 single alphasonik sub. wired up at 1ohm.
after having problems with the system, i decided to check the sub with a multimeter to see if its blown.
my reading was 1.5ohms. is this normal if its wired up at 1ohm?
thanks. and help would be appreciated!
the amp is seeing a 2 ohm load, round that up to 2 ohm....
what u mean?
is it a blown sub?, it used 2 work perfectly till the bass started getting cut off, now its dead for ever.
coz its a single sub, i can only wire it parallel - 1 ohm or series to 4ohm.
what u mean?
what i mean is... the amp is seeing a 2 ohm load.. 5% tolerance.. so like math round it to the next tenth... makes 2 ohm's...( 1.5 rounded up is 2 ohm)
is the sub dual or single voice coil??
its a dual.
so what could be the possible factors why its showing a 2 omh(1.5ohm) load when its wired 2 a 1ohm?
NINYO
NINYO
Spain
NINYO
