Ohm equation help
(Power @ 2 ohm)(.5)+(power @ 2 ohm)/(3)
Ocorrect me if I'm wrong.
Let's try it this way...
3 X 4 ohm in parallel = 1.33 ohms which might be too low for the amp? (I dunno the specs). Or 3 X 1 ohm in series = 3 ohms (original posters idea?)
So, the amp will put out 2500 watts @ 2 oms, which is 70.7 volts. At 3 ohms that should be 1666 watts.
You'll likely rise >2 ohm anyway. That's your best bet right there.
What do you mean by rise?
Thank you!
KJThaDon
KJThaDon
Westland. Michigan
KJThaDon
vegang
vegang
