Ohm equation help
it depends on the efficiency of the amp... and even than you cant calcuate exactly what they are getting
what are you talking about here? you're saying that there's no way to see how much power is going to the subs nor there is no tool for that either?
I am trying to figure out in theory what it should be...
Ok, my amp is rated 2500 RMS @ 2 ohms thats the lowest imp
My subs are DVC 12"s 750 RMS x 3 = 2250 RMS
But the only way I can wire them to the amp is by going 3 ohms, right??
So how much RMS theoretically should they get running @ 3 ohms??
around 700watts rms to each take 50-100 watts
---------- Post added at 10:28 AM ---------- Previous post was at 10:28 AM ----------
what are the speakers wired at, do you know?
3 ohms
How did you come up with that answer. What's the equation?
You'll likely rise >2 ohm anyway. That's your best bet right there.
3 ohms
(Power @ 2 ohm)(.5)+(power @ 2 ohm)/(3)
Ocorrect me if I'm wrong.
KJThaDon
KJThaDon
Westland. Michigan
KJThaDon
vegang
vegang
