Odd rectangular box, port dimension help
pimpnyou204
Ok I have 2 AQ HDC3 12s im building a box for and basically the dimensions of my box have to be..
28 wide
30 deep
15 height (subwoofer side facing the trunk)
11 height (facing the front of the car)
I have an extremely odd shaped trunk space to work with so i pretty much have to work with that. Now my question is can anyone figure out the depth of my port and the width of it for it to be tuned to 38hz. But heres the issue im running into i want subs facing the trunk and the port to the front, but i cant find anywhere that would calculate that for me. If anyone can help me id much appreciate it.
Thanks
I can't fit the subs and port on the same side I've only got about 28 maybe 29 squeezing on width. I'm doing 38 bcuz that's all I've ran so far. What would u suggest 35? I went to this place and first thing they said from 2 dif ppl was "your ports in the wrong spot." they say subs back port front, so that's what I was gonna try to accomplish now. I'm still learning but correct me if I'm wrong but if u want low lows it's best to put your port off in a corner or the back to bounce off of?
I've never done an aero port how do u attach them to it? Inside the box with screws and glue? And whats a passive radiator sorry for asking so many questions I've just done and redone this box about 4 5 times but each time it's better.
a passive radiator is pretty much a speaker with no voice coil or magnet. it is put in the box along with your active drivers to somewhat tune your box.
a good thing about them is that you get no port noise, especially if you have a little port opening.
i am not too familiar with pr's, but you should at least check them out.
so those who say "you cant tune a sealed box" are wrong.
as far as tuning i would say go as low as possible, best thing to do is get the box designed, figure out what the internal dimensions and gross volume is (LxWxH/1728)
once you have the gross volume subtract the displacement of you woofers. to give you a rough net volume
then figure out where you want to run your port, and what the distance is to the opposite wall, the length you can make your port is that distance minus the diameter of the port. then use the calculator to figure out what you can tune it too with that port length, by the way the usable length of the port when whole is 17" when you measure the port with the flares on you have to subtract 1" to give you the usable space.
also the flares mount to the outside of the box with 1 flare and they run inside the box. how you put them together is up to you, anything from super glue to duct tape works
After a lot of number crunching and PMs i came up with a..
28 width
27 depth
14 height
I wanna try the aero ports and see if their what their cracked up to be plus itd be nice to tune them around pretty easily. Now my question is after putting my numbers in here..
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
i got box volume = 4.88824
So i put it into here
Products Menu
with a tuning freq. of 36 and 1 4 in. port it told me to use a length of 3.4286852863792756 with a flare
now if i do 2 ports it tells me to have a length of 8.783370572758551
with 2 ports why is it so long and is that combing them together or each one is really 8 inches? Or am i supposed to just use one port?
when you use more than one port you have to make them longer because of increased port volume, also i still think you tuning a little on the high side, run the calculator again and see what you come up with at a tuning of 32 for your port length
Everything ive been reading has said that the hdc3's sound better with higher tuning 36-40 but none the less i ordered 2 so i can always try them out long first and work my down as i like it.
pimpnyou204
pimpnyou204
Fort Lauderdale
Phoenix Risen
