Track down the source //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Unplug the RCA's from the amp and turn on the system. If the noise is still there, then you know it's either from the amp or after (like possibly the passive xover, which can pick up noise if located near anything carrying power [power wire, fuse box, etc]). If noise goes away, then you know it comes from a source prior to the amp. So then unplug the RCA's from the HU and see if the noise is still there. Just start working backwards till you isolate the problem area.
