Obsidian amps?
  • 6
Initially I plan to launch some Class-D amps :
OA-1 : 1200 RMS @ 1 ohm
OA-2 : 1800 RMS @ 1 ohm
OA-3 : 2400 RMS @ 1 ohm
They are all under-rated amplifiers by a good margin. The ratings are to be used to mate with the appropriate Obsidian woofers for daily applications.
What I have decided to do after much debate is to stick to extremely proven board designs for these three models; initially I was planning otherwise but decided this route would be best -- of course with some modifications and tweaks. All three models feature more robust than normal power supply MOSFETs.
All of these amps will cut off around 16.0 volts -- they are not made for a 16v electrical system at all. For this you will need to look to Sundown or other brands that support this operation. They are in turn optimized for more power on a 12v system.
Once samples arrive testing and board photographs will follow along with predicted pricing.
They will not be the cheapest amps on the market but they will be a good value, IMO, and they will be backed by known excellent customer service and warranty practices.
I am considering offering extended warranty plans as well for those that value a warranty -- those that do not would not have to pay extra for it. Base warranty will be 1 year and can be extended from there.
8/31/2011 UPDATE:
Various testing collected together :
OA-1 : Rated 1200 @ 1 ohm / 600 @ 2 ohms / 300 @ 4 ohms @ 11v
1 ohm --> 1440 watts @ 13.3v @ 1.91 ohms actual
0.5 ohm --> 1960 watts @ 12.65v @ 1.38 ohms actual
0.5 ohm --> 2130 watts @ 12.2v @ 1.17 ohms actual
0.33 ohm --> 2230 watts @ 14.2v @ 1.11 ohms actual
OA-2: Rated 1800 @ 1 ohm / 900 @ 2 ohms / 450 @ 4 ohms @ 11v
1 ohm --> 2340 watts @ 12.8v @ 1.98 ohms actual
0.5 ohm --> 2640 watts @ 11.7v @ 1.16 ohms actual
0.5 ohm --> 2820 watts @ 12.8v @ 0.9 ohms actual
0.5 ohm --> 2892 watts @ 14.4v @ 1.53 ohms actual
OA-3 : Rated 2400 @ 1 ohm / 1200 @ 2 ohms / 600 @ 4 ohms @ 11v
1 ohm --> 2860 watts @ 12.35v @ 2.01 ohms actual
0.5 ohm --> 3250 watts @ 11.5v @ 1.28 ohms actual
0.5 ohms --> 3460 watts @ 11.6v @ 0.86 ohms actual
0.33 ohm --> 3810 watts @ 13.6v @ 0.85 ohms actual
All amps will be upgraded from IRFP064N power supply FETs to IRF1405 power supply FETs for production... the OA-1 and OA-2 will receive a few % tolerance tweaking in the protect circuit for a tad more power output at lower loads and the OA-1 will lose the internal fusing so there won't be concern for blowing the fuses on burps.
All pricing will include a 1-year warranty on the amps for 1 ohm operation on the Class-D models and rated 2 ohm stereo / 4 ohm mono on the multi-channels. We will offer discounted replacements for out-of-warranty operation parameters such as 0.5 ohm and so forth; so you simply are not up the creek in these situation.
OA-1 : $350 + SH
OA-2 : $425 + SH
OA-3 : $675 + SH
This is USA pricing and also for countries without a distributor. We expect to have them distributed in a few other countries upon launch and pricing will be set in those countries by the distributor based on their costs to import, etc.
I will be working on pricing for extended warranty options as well for those that desire longer coverage.
Pre-order pricing will be introduced when pre-ordering is ready to open; it will of course be less than the regular price listed above. 2-channel and 4-channel pricing will be announced later on as well. At this time the ETA is not set in stone on the amps -- we WILL announce it when there is information on that.
i saw pricing somewhere a long long time ago they seem to be half way decent, i'll see if i can find it again.
Awesome. They look promising. Exceed rated pretty well on low voltage.
386
527
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Dtrom
MAF
Dtrom
xShoWTeKx
