Obsession with LOW OHM LOADS
JEFFakaMAX
Noise Complaint Recipient
Is it just a **** measuring competition to claim you have a bazillion watts or is the general consensus that you can really "hear" the difference between a (4ohm & 2 ohm load) or (1ohm to .5ohm)?
Is the loss of sound quality and cooking your amp really worth it for daily use? Competition, I can understand that. Every bit counts.
Before the flaming starts, this has been my "recommended reading" to the novices I encounter that either have no clue and want to learn, or think they know it all and want to argue.
This is the latest version of ZED's manual. While I am not trying to endorse their products, the first several pages of the manual are filled with useful information that may clarify things for those just cutting their teeth.
http://www.zedaudiocorp.com/pdfs/ZedManual-2011.pdf
Page 7 addresses the low ohm load issue.
Stephen Mantz is to car audio as Bob Carver is to home audio. (My opinion)
what about robert zeff
Not true, unless you're not willing to buy used.
no way youre gonna find 1000 @ 4 thats cheaper than 1000 @ 1. and in the chances that you do find it, it's most likely a 4 channel that does 500 x 2 @ 4, and even then that's a class A/B which isn't nearly as efficient as a class D
---------- Post added at 06:55 PM ---------- Previous post was at 06:55 PM ----------
Im not sure why this topic keeps coming up. Who got to arbitrarily decide that all amplifiers sound bad and over heat below 4ohms?
it's probably a placebo for some poeple
Find me 4k at 4ohm thats efficient atleast 75% for under 1000. I can get 4k at 1ohm 79% efficient at that load new for 750
302
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
508
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
4K
JEFFakaMAX
JEFFakaMAX
Just outside of my comfort zone
Kangaroux
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
