nuts and bolts speaker terminals
if you have a brain, you can figure this out....
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy:
//content.invisioncic.com/y282845/emoticons/wowflash.gif.89a61f4caede63a11dac36e97d61323e.gif
nut and bolts for terminals in box anyone know exactly what i need dont want to drill two holes and run to speaker wire through i like the nuts and bolts i ideas
read above......you answered your own questiong TWICE, in the form of you asking the exact question.
but if your still lost......
2 bolts
4 nutes
4 LOCK washers
ring terminals (for each wire going to said bolt)
**common sense**
or if you really want to get technical...
1 bolt per pos/neg of each sub. so..... for a DVC sub....
2 bolts for +'s
2 bolts for -'s
2 washers per bolt = 8 washers
2 lock washers per bolt = 8 lock washers.
this lets you change your ohm load //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
come on guys don't be an *** to the guy i know its a dumb question it may sseem to you guru's (yea right) but its a good question nonetheless, he asked it cause he wanted to know some of you guys thoughts on it all.
but to answer your question bro yes you can do this but the drilling of a small speaker wire hole isn't a big deal on your box trust me i do it all the time an it don't make a difference. if i see where someone gained 3db's by not drilling the holes i will start not drilling holes myself.
but you can also drill the hole, run you speaker wire as long as you need be, then fill in the hole wit some sort of filler if your that worried about it. but if you want to do the nuts an bolts i think the guy about 3 posts up above my own did a good write up of it.
2 bolts
4 nutes
4 LOCK washers
**common sense**
2 bolts for +'s
2 bolts for -'s
This is the way to do it if you have multiple DVC subs and want to run 2ohm daily but .5ohm for competition.
jdmferio13
feayfm
jdmferio13
Central,PA
fyi-future-star
